[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
Rainer Hurling rhurlin at gwdg.de
Mon Jun 24 04:33:05 PDT 2019
Am 24.06.19 um 13:02 schrieb Nyall Dawson:
> On Mon, 24 Jun 2019 at 20:48, Rainer Hurling <rhurlin at gwdg.de> wrote:
>> Hi Nyall,
>> Am 24.06.19 um 01:33 schrieb Nyall Dawson:
>>> On Sat, 22 Jun 2019 at 16:55, Rainer Hurling <rhurlin at gwdg.de> wrote:
>>>> As the maintainer of the QGIS port for FreeBSD, I am preparing a port
>>>> for the recent update to QGIS 3.8.0.
>>>> This seems to happen since #18fb3f2 [1] (committed 2019-05-13, submitted
>>>> 2019-04-30). Before the commit, the build process takes a normal
>>>> duration on FreeBSD.
>>>> As far as I can say, the problem occurs with both proj-5.1.0 and
>>>> proj-6.1.0. GDAL version is 2.4.1, the OS is FreeBSD 13-0 CURRENT amd64.
>>> Hmm - perplexing. Most of that commit should be ifdefed out for proj <
>>> 6 builds. I wonder if you tried trimming the contents of
>>> qgscoordinatereferencesystem_legacy.h to just a couple of sample lines
>>> as a test? Maybe there's something in the compiler which doesn't like
>>> the large static QMap...
>>> Nyall
>> Many thanks for your response.
>> After trimming the contents of qgscoordinatereferencesystem_legacy.h
>> (about 10 lines left), it builds in a normal time again.
>> So it is likely, that the problem on FreeBSD has something to do with
>> its compiler suite? I am using FreeBSD clang version 8.0.1
>> (branches/release_80 363030) (based on LLVM 8.0.1).
>> Is there any workaround, which lets me use the whole contents again?
> You could try swapping the QMap for a std::unordered_map and see if
> there's any benefit.
> Nyall
I am afraid I have no clue how to do this, because I am not a c++ coder.
Is it within qgscoordinatereferencesystem_legacy.h
(sAuthIdToQgisSrsIdMap?) or better in qgscoordinatereferencesystem.cpp
(at lines:386-405?).
As I said in my initial posting, the build duration problem exists on
both, proj 5.1.0 and 6.1.0 on FreeBSD ...
Rainer
More information about the QGIS-Developer mailing list
