[QGIS-Developer] QGIS Desktop as WMS client - purpose of format "Feature"
Andrea Peri aperi2007 at gmail.com
Thu Jun 27 09:52:25 PDT 2019
Forget to add other explanations:
The retrieve geometry from wms is useful also because is in any available
srs.
So the user can have one single geometry in an srs reprojected on server
rather than on qgis.
This is better because the wms server can reproject using proprietary grids
Meanwhile the reprojection on qgis is without proprietary grid and so less
exact.
Regards,
A
Il gio 27 giu 2019, 18:48 Andrea Peri <aperi2007 at gmail.com> ha scritto:
> Hi,
> We use the feature option in getfeatureinfo in qgis to allow the users to
> retrieve the geometry from a feature on the map.
> This really useful rather than wfs because wfs is inefficient and we often
> dont want allow the downloading of the featureset.
> So we disable the wfs and suggest to the users to retrieve one single
> geometry using the feature option in getfeatureinfo in qgis wns client.
> Regards,
> A.
> Il gio 27 giu 2019, 14:41 Andreas Neumann <a.neumann at carto.net> ha
> scritto:
>> Hi,
>> Since 2-3 versions (I think) there is, next to html and text, now a third
>> "format" in GetFeatureInfo with the name "Feature".
>> I wonder why this new format was introduced? What is the idea and what
>> are the advantages?
>> I noticed that not all of the data types work well in this new format.
>> For some (e.g. Postgis data types) data is shown in mode text and html, but
>> nothing in "Feature". One such data type are "json" and "jsonb". The
>> display either an empty string when a text widet is assigned or NULL when a
>> List or Key/Value widget is assigned.
>> Thanks for clarifying the purpose of the third format "Feature".
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190627/97d6442f/attachment.html>
More information about the QGIS-Developer mailing list
