[QGIS-Developer] Translation of QGIS ltr and QGIS master
Stefano Campus skampus at gmail.com
Thu Jun 27 11:09:20 PDT 2019
What if a string is present just only in a version?
Il gio 27 giu 2019, 19:51 Alexandre Neto <senhor.neto at gmail.com> ha scritto:
> Hi,
> Won't translating master be a moving target?
> Thanks,
> Alex
> A qui, 27/06/2019, 15:21, Stefano Campus <skampus at gmail.com> escreveu:
>> thank you for your explication.
>> sometimes it happens that a string is first translated and then later
>> corrected.
>> it is clear that now the correction of a string present in the three
>> branches must propagate both towards the ltr and towards the master.
>> and at the moment this must be done by hand.
>> now it's all a bit more complicated, since you have to keep the three
>> branches under control, but at least you can do everything in transifex.
>> I believe that if someone were able to design the control between the
>> versions it would be something that really deserves to be funded directly
>> by
>> qgis.org.
>> thank you all for help and now it's time to translate :-)
>> ciao!
>> s.
>> Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190627/9352d231/attachment.html>
More information about the QGIS-Developer mailing list
