[QGIS-Developer] Translation of QGIS ltr and QGIS master
Alexandre Neto
senhor.neto at gmail.com
Thu Jun 27 10:51:14 PDT 2019
Won't translating master be a moving target?
Thanks,
Alex
A qui, 27/06/2019, 15:21, Stefano Campus <skampus at gmail.com> escreveu:
> thank you for your explication.
> sometimes it happens that a string is first translated and then later
> corrected.
> it is clear that now the correction of a string present in the three
> branches must propagate both towards the ltr and towards the master.
> and at the moment this must be done by hand.
> now it's all a bit more complicated, since you have to keep the three
> branches under control, but at least you can do everything in transifex.
> I believe that if someone were able to design the control between the
> versions it would be something that really deserves to be funded directly
> by
> qgis.org.
> thank you all for help and now it's time to translate :-)
> ciao!
> s.
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190627/50be72cf/attachment-0001.html>
