[QGIS-Developer] Translation of QGIS ltr and QGIS master
Stefano Campus
skampus at gmail.com
Thu Jun 27 07:20:55 PDT 2019
thank you for your explication.
sometimes it happens that a string is first translated and then later
corrected.
it is clear that now the correction of a string present in the three
branches must propagate both towards the ltr and towards the master.
and at the moment this must be done by hand.
now it's all a bit more complicated, since you have to keep the three
branches under control, but at least you can do everything in transifex.
I believe that if someone were able to design the control between the
versions it would be something that really deserves to be funded directly by
qgis.org.
thank you all for help and now it's time to translate :-)
ciao!
s.
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
