[QGIS-Developer] Global settings in QGIS-Server
Andreas Neumann
a.neumann at carto.net
Fri Jun 28 06:40:06 PDT 2019
In the context of evaluating the benefit (or not) of geometry
simplification, triggered by the findings of Oslandia
(https://oslandia.com/en/2019/06/21/qgis-3-and-performance-analysis/) I
wonder how one enables simplification in QGIS server?
On QGIS Desktop, it is a global setting per each user profile. How do I
enable this setting in QGIS-Server? Do I need to specify an .ini-File
with the "QGIS_OPTIONS_PATH" variable? If yes, how do I create such an
ini-file? Do you have an example?
I had a look at
https://docs.qgis.org/testing/en/docs/user_manual/working_with_ogc/server/config.html#advanced-configuration
but couldn't find how I would do this.
Thanks for your help!
Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190628/c33ca1d2/attachment.html>
