[QGIS-Developer] What to do about incorrect SAGA algorithms?
Nyall Dawson
nyall.dawson at gmail.com
Mon Mar 4 17:45:13 PST 2019
On Tue, 5 Mar 2019 at 09:36, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> 2. Copy the saga provider to a NEW "saga-next gen" plugin based
> provider, which targets the current SAGA v7 .2 release ONLY. This
> would be a community-maintained plugin (although, as a once off
> goodwill gesture I'm willing to do the initial plugin setup and host
> it on a North Road github repo). This plugin could be installed
> alongside the inbuilt SAGA LTR provider without issue, but it would
> NOT be included in a default QGIS install and users would have to
> manually install it via the plugin installer.
Here's an (experimental) working version:
https://plugins.qgis.org/plugins/processing_saga_nextgen/
Seems to be working ok for the couple of algorithms I've run it with,
but definitely experimental only for now ;)
Nyall
> I think this approach is the best solution when could get given the
> constraints we are working around.
> Nyall
