[QGIS-Developer] What to do about incorrect SAGA algorithms?
Nyall Dawson nyall.dawson at gmail.com
Thu Mar 7 17:34:05 PST 2019
On Fri, 8 Mar 2019 at 07:21, Rainer Hurling <rhurlin at gwdg.de> wrote:
> Hi Nyall,
> Thanks for this new plugin. It would be nice, if we could use this
> plugin for SAGA GIS >= 7.2., because some of us use SAGA GIS 7.3.0
> (devel version).
Good point! Can you file a bug ticket on the plugin page and I'll look
into this. Should be a matter of just removing the == part of the
check and replace with a >= part.
Nyall
> Many thanks in advance and best wishes,
> Rainer Hurling
> Am 05.03.19 um 02:45 schrieb Nyall Dawson:
> > On Tue, 5 Mar 2019 at 09:36, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> >> 2. Copy the saga provider to a NEW "saga-next gen" plugin based
> >> provider, which targets the current SAGA v7 .2 release ONLY. This
> >> would be a community-maintained plugin (although, as a once off
> >> goodwill gesture I'm willing to do the initial plugin setup and host
> >> it on a North Road github repo). This plugin could be installed
> >> alongside the inbuilt SAGA LTR provider without issue, but it would
> >> NOT be included in a default QGIS install and users would have to
> >> manually install it via the plugin installer.
> > Here's an (experimental) working version:
> > https://plugins.qgis.org/plugins/processing_saga_nextgen/
> > Seems to be working ok for the couple of algorithms I've run it with,
> > but definitely experimental only for now ;)
> > Nyall
> >> I think this approach is the best solution when could get given the
> >> constraints we are working around.
> >> Nyall
More information about the QGIS-Developer mailing list
