[QGIS-Developer] What to do about incorrect SAGA algorithms?
Rainer Hurling
rhurlin at gwdg.de
Thu Mar 7 13:20:53 PST 2019
Hi Nyall,
Thanks for this new plugin. It would be nice, if we could use this
plugin for SAGA GIS >= 7.2., because some of us use SAGA GIS 7.3.0
(devel version).
Many thanks in advance and best wishes,
Rainer Hurling
Am 05.03.19 um 02:45 schrieb Nyall Dawson:
> On Tue, 5 Mar 2019 at 09:36, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> 2. Copy the saga provider to a NEW "saga-next gen" plugin based
>> provider, which targets the current SAGA v7 .2 release ONLY. This
>> would be a community-maintained plugin (although, as a once off
>> goodwill gesture I'm willing to do the initial plugin setup and host
>> it on a North Road github repo). This plugin could be installed
>> alongside the inbuilt SAGA LTR provider without issue, but it would
>> NOT be included in a default QGIS install and users would have to
>> manually install it via the plugin installer.
> Here's an (experimental) working version:
> https://plugins.qgis.org/plugins/processing_saga_nextgen/
> Seems to be working ok for the couple of algorithms I've run it with,
> but definitely experimental only for now ;)
> Nyall
>> I think this approach is the best solution when could get given the
>> constraints we are working around.
>> Nyall
