[QGIS-Developer] Vagrant file for QGIS-Django
Nathan Woodrow madmanwoo at gmail.com
Fri Mar 8 04:05:36 PST 2019
haha yes I know but for some reason I can't get docker to run well on
Windows at the moment for me, so I will just run it inside a vagrant box
because it's turtles all the way down.
Richard,  could I get some details on how to set this up?
On Fri, Mar 8, 2019 at 9:59 PM Tim Sutton <tim at kartoza.com> wrote:
> Hi
> Vagrant is so 2000s :-p Everything runs in docker. We have it in a a
> private docker hub repo as image contains a working db snapshot too..
> Richard is the gate keeper for getting access to the hub repo after which
> you should be able to do:
> docker login
> docker run -ti -p 8099:80 \
>         -d --restart=unless-stopped \
>         --name="plugins" \
>         -v ${PWD}/static:/home/plugins/QGIS-Django/qgis-app/static \
>         -v ${PWD}/backups:/backups \
>         -v ${PWD}/tmp:/tmp \
>         -v ${PWD}/logs:/var/log/nginx \
>         qgis/plugins:latest \
>         supervisord -n
> The volume mounts are not strictly necessary - we store teh actual plugin
> packages in a host directory instead of the container.
> Regards
> Tim
> On 08 Mar 2019, at 13:41, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey,
> Is there any premade vagrant file I can use for the QGIS-Django project
> that already has everything set up?
> If not I can make one as I run Windows most of the time and I would like
> to have something set up I can just run up and shutdown nicely to match
> what we have running on https://plugins.qgis.org without having to
> install anything local on my windows machine.
> Keen to see if others with more experience have done work in this area
> before so I don't have to reinvent it, but happy to do it if other haven't.
> Regards,
> Nathan
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> *Tim Sutton*
> *Co-founder:* Kartoza
> *Ex Project chair:* QGIS.org
> Visit http://kartoza.com to find out about open source:
> Desktop GIS programming services
> Geospatial web development
> GIS Training
> Consulting Services
> *Skype*: timlinux
> *IRC:* timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190308/20c94349/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190308/20c94349/attachment.jpg>
More information about the QGIS-Developer mailing list
