[QGIS-Developer] Translation of QGIS ltr and QGIS master
DelazJ
delazj at gmail.com
Fri Mar 15 08:24:40 PDT 2019
Hi S.,
This is a valid issue that also bothers me for a long time (and I think is
not coherent with the LTR status).
And Jürgen Fischer recently pushed a PR that gives me some hope: see
https://github.com/qgis/QGIS/pull/9331 (basically, they are commands that
help to backport transifex translations to elder releases). I quickly gave
it a try but the result did not satisfy me and wanted to do more tests
before reporting anything and bothering Jürgen with beginner's problem. If
you want to give it a try... And maybe, instead of running that only for
german, we could run it for all the languages.
I also opened https://github.com/qgis/QGIS-Website/issues/592 few weeks
ago, asking for a place where we could explain how LTR can be translated
more than only the few weeks preceeding its .0 release.
Regards,
Harrissou
Le ven. 15 mars 2019 à 15:50, skampus <skampus at gmail.com> a écrit :
> Dear all, the experience just ended of the first LTR version of QGIS leads
> me
> to make some considerations regarding the management of translations.
> Many QGIS users are users who work in companies and public administrations;
> these users cannot freely choose on which version to operate and therefore
> they will use the LTR version even beyond its end of life.
> So the problem of harmonizing translations between the LTR version and the
> master version is a very important aspect.
> As you know, the sources of the GUI and documentation relating to the
> master
> version are made available through the transifex platform. When the LTR
> version is released, transifex continues to feed only the master version
> and
> therefore untranslated or worse badly translated strings can no longer be
> treated with transifex.
> I ask how to resolve this situation.
> for example, would it be possible to open a transifex instance ONLY for
> 3.4.x ltr? people translate and, as for the master, at every release of the
> ltr, the translation files are automatically taken from transifex "ltr".
> I know that it is possible to translate with qtlinguist and then to do a
> pull request for .qm language file, but in this way it is not possible to
> translate all together with problems for merging different version andd so
> on.
> what is your opinion?
> thank you in advance
> s.
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190315/e84f41b4/attachment.html>
