[QGIS-Developer] Documentation: pyqgis cookbook python code tests
Richard Duivenvoorde
rdmailings at duif.net
Sat Mar 16 06:02:11 PDT 2019
See also:
https://docs.qgis.org/testing/en/docs/documentation_guidelines/cookbook_guidelines.html
R
On 16/03/2019 11.05, Richard Duivenvoorde wrote:
> Hi,
> For those not aware of Arnaud's work during the Hackfest:
> His work makes it relatively easy to test the python snippets in the
> pyqgisbook. In this way keeping the python snippets up to date with
> code/api changes of QGIS itself is much easier.
> We use a Sphinx extension:
> https://www.sphinx-doc.org/en/master/usage/extensions/doctest.html
> In short:
> - you run the snippets from within the cookbook rst using QGIS(libs)
> either from your build/install dir, OR from within a QGIS-Desktop docker
> instance (same as is being used for automatic tests)
> - so we (have to!) adapt the code in the pycookbook a little to make it
> testable (adding testsetup:: and testcode:: directives)
> - he slightly changed the way you can build the documentation (on Linux)
> using one or two extra make (.mk) files.
> See:
> https://github.com/qgis/qgis-documentation#testing-python-snippets
> I've just tested and this 1 test :-) works flawlessly if you create a
> 'user.mk' pointing to your QGIS_PREFIX_PATH
> So: now we can make all code snippets testable!
> If I am correct he was also busy to get the code examples in the
> doxygen/pyqgiscook work with this too @arnaud ?)
> Please try!
> Regards,
> PS this is Sphinx/Python only, but if somebody jumps in to make it work
> in a Windows way this would be even nicer. Or we should update the paver
> way again?
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
