[QGIS-Developer] Documentation: pyqgis cookbook python code tests
Luigi Pirelli luipir at gmail.com
Sun Mar 24 13:52:14 PDT 2019
impressive... tnx Arnoud
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Sat, 16 Mar 2019 at 14:02, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> See also:
> https://docs.qgis.org/testing/en/docs/documentation_guidelines/cookbook_guidelines.html
> R
> On 16/03/2019 11.05, Richard Duivenvoorde wrote:
> > Hi,
> > For those not aware of Arnaud's work during the Hackfest:
> > His work makes it relatively easy to test the python snippets in the
> > pyqgisbook. In this way keeping the python snippets up to date with
> > code/api changes of QGIS itself is much easier.
> > We use a Sphinx extension:
> > https://www.sphinx-doc.org/en/master/usage/extensions/doctest.html
> > In short:
> > - you run the snippets from within the cookbook rst using QGIS(libs)
> > either from your build/install dir, OR from within a QGIS-Desktop docker
> > instance (same as is being used for automatic tests)
> > - so we (have to!) adapt the code in the pycookbook a little to make it
> > testable (adding testsetup:: and testcode:: directives)
> > - he slightly changed the way you can build the documentation (on Linux)
> > using one or two extra make (.mk) files.
> > See:
> > https://github.com/qgis/qgis-documentation#testing-python-snippets
> > I've just tested and this 1 test :-) works flawlessly if you create a
> > 'user.mk' pointing to your QGIS_PREFIX_PATH
> > So: now we can make all code snippets testable!
> > If I am correct he was also busy to get the code examples in the
> > doxygen/pyqgiscook work with this too @arnaud ?)
> > Please try!
> > Regards,
> > PS this is Sphinx/Python only, but if somebody jumps in to make it work
> > in a Windows way this would be even nicer. Or we should update the paver
> > way again?
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190324/27c0d541/attachment.html>
More information about the QGIS-Developer mailing list
