[QGIS-Developer] Why is .qgz the default format?
Régis Haubourg
regis.haubourg at gmail.com
Fri Mar 22 07:29:45 PDT 2019
Hi Rémi,
you can use the global settings ini file to override default option for
QGIS.
There is an option to start QGIS with another default setting file
--globalsettingsfile
https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_configuration.html#running-qgis-with-advanced-settings
You can have a look at how the french ministry of ecology handles this
issue here:
http://www.geoinformations.developpement-durable.gouv.fr/qgis-package-3-4-2-pour-test-a3662.html
Best regards,
Régis
Le ven. 22 mars 2019 à 15:14, Rémi Bovard <remi.bovard at gmail.com> a écrit :
> Hi all,
> Matthias Kuhn 🌍 wrote
> > Currently I'm inclined to prefer Andreas' proposal to have a
> > (well-hidden advanced) setting to let power-users and admins switch the
> > default format.
> I would like to know if this possiblity of using a setting to set default
> format has been implemented?
> I'm currently planing to upgrade our 50+ QGIS 2.18 to QGIS 3.4 with a
> custom
> QGIS3.ini and I really want to be able to set default project format to
> *.qgs.
> Like Andreas, sometimes I need to do some mass projects edits (currently we
> have 150+) and it works well with a global `search and replace` with
> Notepad++. The workaround proposed by Jorge Gustavo Rocha could be fine to
> edit 1 file but not for a mass edit.
> Thanks in advance for your answer.
> Rémi
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190322/aa340822/attachment.html>
