[QGIS-Developer] Qgis 3.6.0 fail to read shapefile with python on buster
David Marteau
dmarteau at 3liz.com
Tue Mar 26 09:45:05 PDT 2019
The situation seems to be worst: it seems that no layers can be read from python whatever the format.
> Le 26 mars 2019 à 17:38, David Marteau <dmarteau at 3liz.com> a écrit :
> Hi devs,
> We use to build docker images of the latest qgis releases and we have a regression affecting version 3.6.0 official release on buster
> Qgis: 3.6.0 on Debian
> If we read a layer with python:
>> layer = QgsVectorLayer('./mydata.shp')
> Then the layer is invalid (no warning, no errors)
> Doing the same thing on stretch + Qgis 3.4.5 (ltr) with same data work flawlessly and lead to a valid layer.
> This was not affecting previous build 24 h ago (release end nightly-release)
> The tests were based with shapefiles from testdata in qgis sources.
> We are not sure it that come from Qgis itself or from a change on the distribution.
> David,
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190326/42be11d2/attachment.html>
