[QGIS-Developer] Qgis 3.6.0 fail to read shapefile with python on buster
Jürgen E. Fischer
jef at norbit.de
Thu Mar 28 15:45:51 PDT 2019
Hi David,
On Thu, 28. Mar 2019 at 19:25:15 +0100, David Marteau wrote:
> I have found the problem, qgis packaging on buster is totally broken: it mixes 3.6.0 and 3.6.1 dependencies
> If you try to install python-qgis you get the following packages installed:
You should install python3-qgis.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190328/2db33727/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190328/2db33727/attachment.ksh>
