[QGIS-Developer] Qgis 3.6.0 fail to read shapefile with python on buster
David Marteau dmarteau at 3liz.com
Fri Mar 29 01:13:11 PDT 2019
Hi Jürgen,
Thanks. Installing only  python3-qgis leads to a better situation:
ii  libqgis-3d3.6.1                         1:3.6.1+15buster            amd64        QGIS - shared 3d library
ii  libqgis-analysis3.6.1                   1:3.6.1+15buster            amd64        QGIS - shared analysis library
ii  libqgis-core3.6.1                       1:3.6.1+15buster            amd64        QGIS - shared core library
ii  libqgis-customwidgets                   1:3.6.1+15buster            amd64        QGIS custom widgets for Qt Designer
ii  libqgis-gui3.6.1                        1:3.6.1+15buster            amd64        QGIS - shared gui library
ii  libqgis-native3.6.1                     1:3.6.1+15buster            amd64        QGIS - shared native gui library
ii  libqgis-server3.6.1                     1:3.6.1+15buster            amd64        QGIS - shared server library
ii  libqgispython3.6.1                      1:3.6.1+15buster            amd64        QGIS - shared Python library
ii  python3-qgis                            1:3.6.1+15buster            amd64        Python bindings to QGIS
ii  python3-qgis-common                     1:3.6.1+15buster            all          Python bindings to QGIS - architectu
But the providers  are missing: you need also to install the 'qgis-providers' package which, fortunately, has dependencies
only on 3.6.1 package version.
David
> Le 28 mars 2019 à 23:45, Jürgen E. Fischer <jef at norbit.de> a écrit :
> Hi David,
> On Thu, 28. Mar 2019 at 19:25:15 +0100, David Marteau wrote:
>> I have found the problem, qgis packaging on buster is totally broken: it mixes 3.6.0 and 3.6.1 dependencies
>> If you try to install  python-qgis you get the following packages installed:
> You should install python3-qgis.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden            https://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Juergen Fischer, Nils Kutscher HR: Amtsgericht Aurich HRB 100827
> Datenschutzerklaerung: https://www.norbit.de/83/
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190329/68ce0b32/attachment.html>
More information about the QGIS-Developer mailing list
