[QGIS-Developer] Adding "Requirements" as optional field/entry/line in metadata.txt
Tom Kralidis tomkralidis at gmail.com
Sun Mar 31 06:22:02 PDT 2019
Good idea. Perhaps listing actual Python requirements or pointing to / assessing a requirements.txt type file is pushing it?
..Tom
Sent from my iPhone
> On Mar 31, 2019, at 08:49, Stefan Keller <sfkeller at gmail.com> wrote:
> Hi
> As a user when searching and browsing for a plugin in QGIS extension
> manager or on the website https://plugins.qgis.org/ , I think users
> should be informed before hand about the requirements, dependencies
> and restrictions of a plugin.
> These are possible requirements, dependencies and restrictions which
> come to my mind: The plugin...
> * is running only on one platform
> * is depending on some other SW to be installed separately (because
> it's not included in the QGIS installation),
> * requires some registration or account.
> My suggestion is to add an optional field/entry/line in metadata.txt
> called "Requirements" where requirements, dependencies and
> restrictions are to be described.
> This entry would be mandatory if there exist such requirements. Some
> dependencies and restrictions could potentially even be potentially
> validated automatically.
> :Stefan
> P.S. I actually also thought about adding a "spatial extends"
> attribute in metadata.txt in order to indicate that this plugin only
> works for some specific countries or regions. But for now I'd just
> prefer that the chapter "Recommendations" on
> https://plugins.qgis.org/publish/ is being extended to mention that
> spatial limitations to be mentioned in the plugin description!
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
