[QGIS-Developer] how to make sure QGIS3 is always started by calling qgis.bat and not qgis.exe?
Thomas Baumann
rdbath.regiodata at gmail.com
Mon May 6 00:54:21 PDT 2019
Hello QGIS-Devs,
I recently asked a question on gis.stackexchange about how to make sure
that QGIS3 is always started by calling the qgis.bat file:
https://gis.stackexchange.com/questions/321108/check-whether-qgis3-was-started-by-qgis-bat-or-qgis-exe
( The reason why I want to make sure that qgis.bat is used is that I have
added a md5-check which checks the startup.py in the users profile path
against the current startup.py I want to rollout on all clients.)
One idea which was posted on stackexchange was to intentially break the
connection between qgis.exe and the *.env/*.var files qgis expects to find
in order to make sure QGIS can obly be started by calling the qgis.bat file.
I am just wondering if it is safe to use QGIS3 without the information in
the *.env and *.var files or is this rather a bad idea?
Any other ideas how to make sure everyone uses the current startup.py?
regards,
Thomas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190506/b1102930/attachment.html>
