[QGIS-Developer] Building QGIS with Ninja on Windows - python37_d.lib
Olivier Dalang olivier.dalang at gmail.com
Thu May 9 03:32:04 PDT 2019
I was able to run prepare-commit from WSL by commenting out these lines
(74-76) in astyle.sh :
# if type -p wslpath >/dev/null; then
#   ASTYLEOPTS="$(wslpath -a -w "$ASTYLEOPTS")"
# fi
It seems they were trying to convert path of the astyle option files from
WSL to Windows (/mnt/c/... to c:\). Not sure if this is specific to my
setup ?
On Wed, 8 May 2019 at 19:53, Olivier Dalang <olivier.dalang at gmail.com>
wrote:
> I saw the reference to package-nightly.cmd, but it's not that easy to
> follow, at least it wasn't for me. I was thinking of a note like [1] to
> help out other new commers. If it makes sense, I can open a PR.
> Also, I'm now stuck with the prepare-commit.sh step under Windows.
> I tried with WSL, where the script runs, but failed because of a few
> dependencies (astyle itself, autopep8 and a few others, all of which were
> easy to apt-get install), but it still fails after that with :
> Cannot open default option file /mnt/c/Users/Olivier/Documents/QGIS/C:
> Artistic Style has terminated
> I also tired to build with WITH_ASTYLE=ON as suggested on [2], but that
> didn't seem to have any effect. I did it like this :
> $ cmake -G Ninja -D CMAKE_BUILD_TYPE=RELWITHDEBINFO -D WITH_ASTYLE=ON ..
> $ ninja
> Is this the correct way to do it ?
> Thanks !!
> Olivier
> [1] :
> https://github.com/qgis/QGIS/compare/master...olivierdalang:ninja_instructions_for_win?expand=1
> [2] :
> https://lists.osgeo.org/pipermail/qgis-developer/2017-July/049324.html
> On Wed, 8 May 2019 at 10:24, Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Olivier,
>> On Wed, 08. May 2019 at 10:05:27 +0200, Olivier Dalang wrote:
>> > Thanks, that was it !
>> > I wasn't giving the CMAKE_BUILD_TYPE argument to CMAKE. I'll make a PR
>> > shortly to add this info to INSTALL.
>> doc/msvc.t2t - INSTALL is an output file.
>> A note to refer to package-nightly.cmd is already there.
>> Jürgen
>> Jürgen E. Fischer         norBIT GmbH               Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
>> +49-4931-918175-50
>> Software Engineer         D-26506 Norden
>> https://www.norbit.de
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190509/d44dec90/attachment.html>
More information about the QGIS-Developer mailing list
