[QGIS-Developer] adding vertices to digitize session via python
Jonas qgis at ag99.de
Thu May 9 23:10:39 PDT 2019
Hello again,
nevermind, figured it out.
just casting the map tool to QgsMapToolCapture does the trick:
from qgis.core import QgsPointXY from qgis.gui import QgsMapTool,
QgsMapToolCapturefrom qgis.PyQt import sipmapToolCapture =
sip.cast(iface.mapCanvas().mapTool(), QgsMapToolCapture)
mapToolCapture.addVertex(QgsPointXY(1,2))
Cheers
Jonas
On 09.05.2019 12:55, Jonas wrote:
> Hi,
> is there a way to add vertices to the rubberband when the user
> currently digitizes a feature via the python API?
> For example when adding a line feature, the user has already created a
> few vertices of a line via the rubber band. now i want to add the next
> vertex of that rubber band via python. I do NOT want to end the users
> action to create the feature, or add vertices to already existing
> features.
> I think that would mean calling addVertex() on a
> QgsMapToolCapture-object. However i cannot find a way to retrieve a
> QgsMapToolCapture-object from the current mapTool.
> Is there a way to do this?
> Thanks
> Jonas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190510/b41befc4/attachment.html>
More information about the QGIS-Developer mailing list
