[QGIS-Developer] Explode HStore algorithm
DelazJ delazj at gmail.com
Sun May 12 09:24:32 PDT 2019
See the Processing toolbox
https://qgis.org/en/site/forusers/visualchangelog36/index.html#feature-explode-hstore-algorithm
regards,
Harrissou
Le dim. 12 mai 2019 à 18:10, <wambacher at posteo.de> a écrit :
> Hi
> Am 12.05.19 um 17:03 schrieb Enrico Ferreguti:
> You can handle hstore using dedicated maps functions in expressions:
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/expression.html#id25
> I know, but the solution:
> *"In QGIS 3.4*, you can use the htsore_to_map expression to get a map
> (dictionary) of the hstore field. Then you can use one of the map
> expressions to manipulate it" (
> https://gis.stackexchange.com/questions/209421/how-to-categorize-features-based-on-hstore-values-in-qgis#288550
> does not work using QGIS 3.6. I tried this without any success.
> There is a solution for 3.6 in the same text, but i can't find any way to
> do that.
> My projects:
> Admin Boundaries of the World <https://wambachers-osm.website/boundaries>
> Missing Boundaries
> <https://wambachers-osm.website/index.php/projekte/internationale-administrative-grenzen/missing-boundaries>
> Emergency Map <https://wambachers-osm.website/emergency>
> Postal Code Map (Germany only) <https://wambachers-osm.website/plz>
> Fools (QA for zipcodes in Germany) <https://wambachers-osm.website/fools>
> Postcode Boundaries of Germany
> <https://wambachers-osm.website/pcoundaries>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190512/f01b98f7/attachment-0001.html>
More information about the QGIS-Developer mailing list
