[QGIS-Developer] Explode HStore algorithm
wambacher at posteo.de wambacher at posteo.de
Sun May 12 09:43:40 PDT 2019
Yes, i know this should be available in the toolbox but the toolbox was
very "small" yesterday. Only 6-7 entries and it did not contain such a
function.
BUT: Yesterday evening i had to do a reboot of my system after about 4
weeks (i'm doing this only if really, really needed) and what? Big
toolbox and the function is available. :)
@enrico: got it running using map functions too: had to change
/map_get(map_to_hstore(tags),'entrance') /into /map_get(tags,'entrance')/ :)
Thanks to both of you - great help.
Walter/
Am 12.05.19 um 18:24 schrieb DelazJ:
> Hi,
> See the Processing toolbox
> https://qgis.org/en/site/forusers/visualchangelog36/index.html#feature-explode-hstore-algorithm
> regards,
> Harrissou
> Le dim. 12 mai 2019 à 18:10, <wambacher at posteo.de
> <mailto:wambacher at posteo.de>> a écrit :
>     Hi
>     Am 12.05.19 um 17:03 schrieb Enrico Ferreguti:
>>     You can handle hstore using dedicated maps functions in
>>     expressions:
>>     https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/expression.html#id25
>     I know, but the solution:
>     *"In QGIS 3.4*, you can use the |htsore_to_map| expression to get
>     a map (dictionary) of the hstore field. Then you can use one of
>     the map    expressions to manipulate it"
>     (https://gis.stackexchange.com/questions/209421/how-to-categorize-features-based-on-hstore-values-in-qgis#288550)
>     does not work using QGIS 3.6. I tried this without any success.
>     There is a solution for 3.6 in the same text, but i can't find any
>     way to do that.
>     My projects:
>     Admin Boundaries of the World
>     <https://wambachers-osm.website/boundaries>
>     Missing Boundaries
>     <https://wambachers-osm.website/index.php/projekte/internationale-administrative-grenzen/missing-boundaries>
>     Emergency Map <https://wambachers-osm.website/emergency>
>     Postal Code Map (Germany only) <https://wambachers-osm.website/plz>
>     Fools (QA for zipcodes in Germany)
>     <https://wambachers-osm.website/fools>
>     Postcode Boundaries of Germany
>     <https://wambachers-osm.website/pcoundaries>
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
My projects:
Admin Boundaries of the World <https://wambachers-osm.website/boundaries>
Missing Boundaries
Fools (QA for zipcodes in Germany) <https://wambachers-osm.website/fools>
Postcode Boundaries of Germany <https://wambachers-osm.website/pcoundaries>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190512/21bdc8fe/attachment.html>
More information about the QGIS-Developer mailing list
