[QGIS-Developer] Trying to build with GDAL3/PROJ6, anybody successful?
Even Rouault even.rouault at spatialys.com
Thu May 16 06:04:07 PDT 2019
Richard,
as I see /home/richard/bin/proj/lib/libinternalproj.so.15 , I assume you built
PROJ with the -DPROJ_RENAME_SYMBOLS trick. So QGIS should also be built with
this define set
you might try adding the following to your ccmake invokation:
-DCMAKE_CXX_FLAGS=-DPROJ_RENAME_SYMBOLS
Even
http://www.spatialys.com
More information about the QGIS-Developer mailing list
