[QGIS-Developer] Can I backport bugfix with UI updates and fixing QGIS Server regression
René-Luc Dhont
rldhont at gmail.com
Mon May 20 08:27:53 PDT 2019
Hi Devs,
I have removed the commit cherry-picked from Nyall's pull-request that
update the layout designer dialog.
So my Pull-request only contains changes for QGIS Server to fix the
regression about printing selection.
I have introduced the capability to print selection in QGIS Server for
version 3.4 LTR with the pull-request [Server] Reactivate the capability
to print selection with Server 3.4 https://github.com/qgis/QGIS/pull/8320
This capability is available for image export and was tested and this
pull-request fix inconsistent use of layout render context flags and add
test to validate it.
I really hope this will be fix it version 3.4.9.
Regards,
René-Luc
Le 14/05/2019 à 10:00, René-Luc Dhont a écrit :
> Hi all,
> In the PR to fix the QGIS Server regression I only need to backport 1
> commit on the 2 provided by Nyall to fix the issue: Layout export -
> raster divided into tiles, edges evident in pdf/svg
> https://issues.qgis.org/issues/19500 in the Pull request
> [needs-docs][layouts] Add checkbox to disable raster tiling for
> PDF/SVG exports https://github.com/qgis/QGIS/pull/9016
> The one I need is a fix: Fix inconsistent use of layout render context
> flags
> https://github.com/qgis/QGIS/pull/9692/commits/0954deaf97638519e9f4b3e28855e03a8a34f5c1
> This one concoenrs only render context flags for PDF and SVG output.
> In the case of image output, the layout render context flags are well
> set.
> So do you think, the Pull Request could be accepted, if I remove the
> UI modifed part and only conserve the modification needed for server ?
> Regards,
> René-Luc
> Le 13/05/2019 à 08:04, Paolo Cavallini a écrit :
>> Hi all,
>> On 12/05/19 09:41, Régis Haubourg wrote:
>>> I'd be pleased to test things here but use cases are so numerous that I
>>> fail to see how to do this efficiently.
>>> I hope we'll one day be able to run those smoke tests as discussed
>>> at La
>>> Coruna.
>> I was about suggesting doing community-wide testing (having a test
>> package would greatly help). Is it so difficult to identify and test
>> possible regression areas?
>> Cheers.
