[QGIS-Developer] Can I backport bugfix with UI updates and fixing QGIS Server regression
Nyall Dawson
nyall.dawson at gmail.com
Mon May 20 15:20:54 PDT 2019
On Tue, 21 May 2019 at 01:28, René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi Devs,
> I have removed the commit cherry-picked from Nyall's pull-request that
> update the layout designer dialog.
> So my Pull-request only contains changes for QGIS Server to fix the
> regression about printing selection.
> I have introduced the capability to print selection in QGIS Server for
> version 3.4 LTR with the pull-request [Server] Reactivate the capability
> to print selection with Server 3.4 https://github.com/qgis/QGIS/pull/8320
> This capability is available for image export and was tested and this
> pull-request fix inconsistent use of layout render context flags and add
> test to validate it.
> I really hope this will be fix it version 3.4.9.
My concerns described in
https://github.com/qgis/QGIS/pull/9692/files#r272405690 still stand.
Nyall
