[QGIS-Developer] Fwd: Qgis server systemd
adib saliba
adibsaliba75 at gmail.com
Thu May 23 00:09:22 PDT 2019
---------- Forwarded message ---------
Date: Thu, May 23, 2019 at 10:08 AM
Subject: Re: [QGIS-Developer] Qgis server systemd
To: Eric <eric.lemoine at oslandia.com>
Dear Eric
Thank you very much for your response
I already followed the link you mentioned, i am using ubuntu 19.04 with
nginx php-fpm postgresql qgis server stable release and lizmap web client
with wmts caching.
my problem is that the memory is not recycling after the main process
finishes (i get all the image tiles), and it is always increasing till the
system is out of memory.
the only solution i found is to use RuntimeMaxSec variable to restart the
service.
please find attached the conf files i'm using
Thanks and best regards
Adib
On Thu, May 23, 2019 at 7:39 AM Eric <eric.lemoine at oslandia.com> wrote:
> Le 22 mai 2019 20:48:06 GMT+02:00, adib saliba <adibsaliba75 at gmail.com> a
> écrit :
> >Dear sirs, I have a question regarding qgis server setup:
> >I deployed qgis server on ubuntu server using nginx+systemd
> >| tried 2types of service : simple and forking with
> >number of process = number of cores.
> >The type=simple is faster but it is not freeing up
> >memory even if I'm using Restart=always, the
> >type=forking is freeing memory but gives error
> >prematurely closed connection to fastcgi upstream.
> >Could you please advise me how to correctly configure the service type
> >simple to freeup memory?
> Hi Adib
> We've been using Type=simple without experiencing the memory issue you are
> seeing. See
> https://oslandia.com/en/2018/11/23/deploying-qgis-server-with-systemd/
> for the actual set-up we use. It would be good to know more about your
> set-up and the memory issue you're having.
> Cheers,
> Éric
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190523/f9bf4c2c/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190523/f9bf4c2c/attachment-0003.obj>
Name: qgis-server-fcgi at .socket
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190523/f9bf4c2c/attachment-0004.obj>
Name: qgis-server-fcgi at .service
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190523/f9bf4c2c/attachment-0005.obj>
