[QGIS-Developer] Qgis server systemd
Eric eric.lemoine at oslandia.com
Wed May 22 21:39:13 PDT 2019
Le 22 mai 2019 20:48:06 GMT+02:00, adib saliba <adibsaliba75 at gmail.com> a écrit :
>Dear sirs, I have a question regarding qgis server setup:
>I deployed qgis server on ubuntu server using nginx+systemd
>| tried 2types of service : simple and forking with
>number of process = number of cores.
>The type=simple is faster but it is not freeing up
>memory even if I'm using Restart=always, the
>type=forking is freeing memory but gives error
>prematurely closed connection to fastcgi upstream.
>Could you please advise me how to correctly configure the service type
>simple to freeup memory?
Hi Adib
We've been using Type=simple without experiencing the memory issue you are seeing. See https://oslandia.com/en/2018/11/23/deploying-qgis-server-with-systemd/ for the actual set-up we use. It would be good to know more about your set-up and the memory issue you're having.
Cheers,
Éric
More information about the QGIS-Developer mailing list
