[QGIS-Developer] Help fixing code for gcc 4.8
Henrik K
hege at hege.li
Thu May 23 01:13:07 PDT 2019
I've no problem fixing minor brace stuff here locally..
Do you have any ideas for the QString/QStringList stuff in
qgswmsrenderer.cpp?
It seems I may need to install redhat developer repository to access gcc
8.2, or perhaps even compile my own gcc. But it would be shame, since
pretty much all software I've ever needed compiles fine with the defaut
toolset with perhaps minor fixes. I'm hoping qgis can still be done.
Cheers,
Henrik
On Thu, May 23, 2019 at 09:46:54AM +0200, Alessandro Pasotti wrote:
> Henrik,
> I'm afraid you will have an hard time: we are using more and more C++11 list
> initialization (aka brace initialization) in the code,
> if your compiler do not support it well, you will get a lot of errors.
> That said if it's just that single line that blocks your porting feel free to
> make a pull request to change it.
> You may also try to remove "auto":
> const QgsLayerTreeLayer* treeLayer { static_cast<const QgsLayerTreeLayer *>(
> childNode ) };
> for some background:
> [1]https://stackoverflow.com/questions/18222926/
> why-is-list-initialization-using-curly-braces-better-than-the-alternatives
> [2]http://isocpp.github.io/CppCoreGuidelines/CppCoreGuidelines#Res-list
> an "amusing" read:
> [3]http://mikelui.io/2019/01/03/seriously-bonkers.html
> On Thu, May 23, 2019 at 9:01 AM Henrik K <[4]hege at hege.li> wrote:
> I'm almost near finishing, but qgswmsrenderer.cpp is throwing a lot of
> errors (for bot 3.4.8 and 3.6.3). Could someone have a look at this:
> [5]https://pastebin.com/JS7uKAZ7
> The two expression errors there I fixed per previous advice..
> const auto { } -> ( )
> Cheers,
> Henrik
> On Wed, May 22, 2019 at 10:50:47AM -0700, Elias Carter wrote:
> > > But if I manage to get this running I'll post all my patches somewhere.
> > Hi Henrik,
> > I would be interested in collaborating with you to get QGIS 3 running on
> RHEL/
> > CentOS 7.
> > Would you be willing to share your current patchset and maybe I can help
> out
> > with getting this working?
> > Thanks,
> > Elias
> > On Wed, May 22, 2019 at 10:40 AM Henrik Krohns <[1][6]hege at hege.li>
> wrote:
> > Thanks, it worked, so simple..
> > Are fixes like this good canditate to actually raise an issue? I have
> no
> > clue
> > on all the C++ versions etc and what stuff is legacy not intended to
> use
> > these days..
> somewhere.
> > On Wed, May 22, 2019 at 05:40:45PM +0200, Alessandro Pasotti wrote:
> > > Hi Henrik,
> > > Try to replace {} with (), such as:
> > > const auto treeLayer ( static_cast<const QgsLayerTreeLayer *>(
> childNode
> > > On Wed, May 22, 2019 at 4:42 PM Henrik Krohns <[1][2][7]
> > > Hello,
> > > I've been trying to compile QGis on RHEL7 / GCC 4.8.5 all day.
> It
> > seems
> > > lots of code assume newer compiler. I've fixed many cases
> already,
> > but
> > > here's something I can't manage.. not really proficient in
> C++..
> > > src/server/services/wms/qgswmsgetcapabilities.cpp: In function
> 'bool
> > > QgsWms::hasQueryableChildren(const QgsLayerTreeNode*, const
> > QStringList&)':
> > > src/server/services/wms/qgswmsgetcapabilities.cpp:1893:31:
> error:
> > base
> > > operand of '->' has non-pointer type 'const
> std::initializer_list
> > <const
> > > QgsLayerTreeLayer* const>'
> > > const auto l { treeLayer->layer() };
> > > src/server/services/wms/qgswmsgetcapabilities.cpp:1893:41:
> error:
> > unable to
> > > deduce 'const std::initializer_list<const auto>' from '
> {<expression
> > error>}
> > > The code..
> > > else if ( childNode->nodeType() ==
> QgsLayerTreeNode::NodeLayer )
> > > const auto treeLayer { static_cast<const
> > > childNode ) };
> > > return ! wmsRestrictedLayers.contains( l->name() ) && l->
> flags
> > > ().testFlag( QgsMapLayer::Identifiable );
> > > Any ideas how to rewrite?
> > > Cheers,
> > > Henrik
> > > _______________________________________________
> > > QGIS-Developer mailing list
> > > [2][3][8]QGIS-Developer at lists.osgeo.org
> > > List info: [3][4][9]https://lists.osgeo.org/mailman/listinfo/
> > qgis-developer
> > > Unsubscribe: [4][5][10]https://lists.osgeo.org/mailman/listinfo
> > qgis-developer
> > > Alessandro Pasotti
> > > w3: [5][6][11]www.itopen.it
> > > References:
> > > [1] mailto:[7][12]hege at hege.li
> > > [2] mailto:[8][13]QGIS-Developer at lists.osgeo.org
> > > [3] [9][14]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > [4] [10][15]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > > [5] [11][16]http://www.itopen.it/
> > [12][17]QGIS-Developer at lists.osgeo.org
> > List info: [13][18]https://lists.osgeo.org/mailman/listinfo/
> qgis-developer
> > Unsubscribe: [14][19]https://lists.osgeo.org/mailman/listinfo/
> qgis-developer
> > References:
> > [1] mailto:[20]hege at hege.li
> > [2] mailto:[21]hege at hege.li
> > [3] mailto:[22]QGIS-Developer at lists.osgeo.org
> > [4] [23]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > [5] [24]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > [6] [25]http://www.itopen.it/
> > [7] mailto:[26]hege at hege.li
> > [8] mailto:[27]QGIS-Developer at lists.osgeo.org
> > [9] [28]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > [10] [29]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > [11] [30]http://www.itopen.it/
> > [12] mailto:[31]QGIS-Developer at lists.osgeo.org
> > [13] [32]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > [14] [33]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [34]QGIS-Developer at lists.osgeo.org
> List info: [35]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: [36]https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: [37]www.itopen.it
> References:
> [1] https://stackoverflow.com/questions/18222926/why-is-list-initialization-using-curly-braces-better-than-the-alternatives
> [2] http://isocpp.github.io/CppCoreGuidelines/CppCoreGuidelines#Res-list
> [3] http://mikelui.io/2019/01/03/seriously-bonkers.html
> [4] mailto:hege at hege.li
> [5] https://pastebin.com/JS7uKAZ7
> [6] mailto:hege at hege.li
> [7] mailto:hege at hege.li
> [8] mailto:QGIS-Developer at lists.osgeo.org
> [9] https://lists.osgeo.org/mailman/listinfo/
> [10] https://lists.osgeo.org/mailman/listinfo/
> [11] http://www.itopen.it/
> [12] mailto:hege at hege.li
> [13] mailto:QGIS-Developer at lists.osgeo.org
> [14] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [15] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [16] http://www.itopen.it/
> [17] mailto:QGIS-Developer at lists.osgeo.org
> [18] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [19] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [20] mailto:hege at hege.li
> [21] mailto:hege at hege.li
> [22] mailto:QGIS-Developer at lists.osgeo.org
> [23] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [24] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [25] http://www.itopen.it/
> [26] mailto:hege at hege.li
> [27] mailto:QGIS-Developer at lists.osgeo.org
> [28] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [29] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [30] http://www.itopen.it/
> [31] mailto:QGIS-Developer at lists.osgeo.org
> [32] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [33] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [34] mailto:QGIS-Developer at lists.osgeo.org
> [35] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [36] https://lists.osgeo.org/mailman/listinfo/qgis-developer
> [37] http://www.itopen.it/
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
