[QGIS-Developer] Issues ID mapping (was: Post github issues migration clean ups - some proposals)
Jürgen E. Fischer
jef at norbit.de
Thu May 30 16:29:09 PDT 2019
Hi Jorge,
On Thu, 30. May 2019 at 09:04:30 +0100, Jorge Gustavo Rocha wrote:
> I'm trying to find old Redmine issue references and replace then by the
> new ones, so everything points to the new ones. Commits messages are not
> easy to change, since the message itself is part of the commit.
> I've just made https://github.com/qgis/QGIS/pull/30014 to have all
> comments in code (and in tests) pointing only to GitHub.
I thought you were also going to investigate how to add a github comment to the
commits with a issue reference. So visiting the commit on github would also
give you a pointer to the github without a history change.
BTW redmine now redirects commit links to the corresponding github page.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190531/988da572/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190531/988da572/attachment.ksh>
