[QGIS-Developer] Use PyQGIS to change a group of selected vertices (vertex tool)
Jo winfixit at gmail.com
Wed Nov 6 05:29:59 PST 2019
I'm also interested in the answer to this question. I was under the
impression that the vertex tool (and thus  what you select in it) is not
accessible from Python.
This is very unfortunate, as I would also like to do something with the
selection of some of those vertices.
Jo
On Wed, Nov 6, 2019 at 12:49 PM Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Hi,
> Having selected a couple of vertices using the Vertex Tool, how can I have
> access to the selected Vertex using PyQGIS, and eventually change them?
> I see that there is a vertex iterator, but I can't seem to understand how
> to get to it.
> Use case: I have 3D lines with some problems in the Z values. I wanted to
> retrieve the nodes, change the z values and update them in the feature
> geometry.
> Thanks,
> Alexandre Neto
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191106/d39f3ee4/attachment.html>
More information about the QGIS-Developer mailing list
