[QGIS-Developer] OSGEO4W messing up Grass versions
Jürgen E. Fischer
jef at norbit.de
Sun Nov 10 06:05:44 PST 2019
On Sun, 10. Nov 2019 at 04:56:26 -0700, magerlin wrote:
> There is no such folder as "C:\OSGeo4W64\bin\bin". There are Grass bat
> files in the folder "C:\OSGeo4W64\bin"
> But the Processing setting dialog does not any more include the path to
> Grass - I can only tell where Grass docs are:
> <http://osgeo-org.1560.x6.nabble.com/file/t202356/Anm%C3%A6rkning_2019-11-10_124950.png>
> Where do I set the path to Grass in QGIS 3.10?
Did you start with the "QGIS with GRASS" shortcut? That should set GISBASE.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191110/eb47a568/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191110/eb47a568/attachment.ksh>
