[QGIS-Developer] Issues installing on ubuntu 19.10
Jürgen E. Fischer
jef at norbit.de
Sat Nov 16 13:06:21 PST 2019
Hi Tim,
On Sat, 16. Nov 2019 at 20:54:23 +0000, Tim Sutton wrote:
> Thanks Juergen - all working now - though it is running against GDAL 2.4.2. I
> was nerdily hoping to get GDAL 3.x in the process :-p
Ubuntu (but also ubuntugis) usually depends on Debian (IOW on Bas Couwenberg's
work), when it comes to FOSSGIS:
On Sun, 10. Nov 2019 at 20:26:02 +0100, Sebastiaan Couwenberg wrote:
> The transition to GDAL 3 was blocked by the removal of the Python 2
> support as discussed in the transition bugreport (#939989). This took
> quite a bit of time to resolve due to an uncooperative maintainer, but
> there are no rdeps of python-gdal in unstable any more.
> In the meantime the GDAL 3 support in fiona was fixed upstream. vtk7 was
> also updated to use the embedded copy of PROJ.4 to fix the FTBFS with
> PROJ 6. OSSIM upstream even ported it to use the GEOS C API to fix the
> build failure with GEOS 3.8.0. Unfortunately OTB still FTBFS due to
> recent changes in ITK4. It's still not in testing, so not a big issue.
> Hopefully we'll be able to start the transition soon, but I fear that
> the python3.8 transition is going to cause more delays (as it will cause
> many autopkgtest failure until everything is rebuilt for python3.8 as well).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191116/95e0b134/attachment.sig>
