[QGIS-Developer] Issues installing on ubuntu 19.10
Tim Sutton
tim at kartoza.com
Sat Nov 16 13:21:35 PST 2019
Hi
Thanks for the info Jürgen ...no worries I will wait for now.
Regards
Tim
Sent from Mailspring (https://link.getmailspring.com/link/719FCF68-9BAC-4975-B7D8-730A5877F651@getmailspring.com/0?redirect=https%3A%2F%2Fgetmailspring.com%2F&recipient=cWdpcy1kZXZlbG9wZXJAbGlzdHMub3NnZW8ub3Jn), the best free email app for work
On Nov 16 2019, at 9:06 pm, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Tim,
> On Sat, 16. Nov 2019 at 20:54:23 +0000, Tim Sutton wrote:
> > Thanks Juergen - all working now - though it is running against GDAL 2.4.2. I
> > was nerdily hoping to get GDAL 3.x in the process :-p
> Ubuntu (but also ubuntugis) usually depends on Debian (IOW on Bas Couwenberg's
> work), when it comes to FOSSGIS:
> On Sun, 10. Nov 2019 at 20:26:02 +0100, Sebastiaan Couwenberg wrote:
> > The transition to GDAL 3 was blocked by the removal of the Python 2
> > support as discussed in the transition bugreport (#939989). This took
> > quite a bit of time to resolve due to an uncooperative maintainer, but
> > there are no rdeps of python-gdal in unstable any more.
> > In the meantime the GDAL 3 support in fiona was fixed upstream. vtk7 was
> > also updated to use the embedded copy of PROJ.4 to fix the FTBFS with
> > PROJ 6. OSSIM upstream even ported it to use the GEOS C API to fix the
> > build failure with GEOS 3.8.0. Unfortunately OTB still FTBFS due to
> > recent changes in ITK4. It's still not in testing, so not a big issue.
> > Hopefully we'll be able to start the transition soon, but I fear that
> > the python3.8 transition is going to cause more delays (as it will cause
> > many autopkgtest failure until everything is rebuilt for python3.8 as well).
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden https://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191116/c2604f19/attachment.html>
