[QGIS-Developer] Temporary folders for processing
Alexander Bruy alexander.bruy at gmail.com
Mon Nov 25 02:06:47 PST 2019
Hi Andreas,
Processing keeps al temporary files and outputs in the user temporary folder,
e.g. C:\Usres\user\AppData\Local\Temp\ on WIndows by default and /tmp on Linux.
пн, 25 лист. 2019 о 11:53 Andreas Neumann <a.neumann at carto.net> пише:
> Hi,
> I would like to know where the temporary files of QGIS processing are stored? I know that there is a setting for default output files (defaults on Windows to C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs - but is this really the same location where also temporary files that are needed during the processing are stored?
> Our issues is that several users share Windows servers and the C partition is only 80GB in size. If 5-10 users are sharing one Windows server, we fear that our C drive is filled really quickly.
> Can we set another temporary drive/folder than "C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs" ? If yes, where do I find this setting?
> Thank you for your help,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
More information about the QGIS-Developer mailing list
