[QGIS-Developer] Temporary folders for processing
Andreas Neumann
a.neumann at carto.net
Mon Nov 25 02:00:07 PST 2019
Hi Nathan,
So it is using the %TEMP% environment variable of the Windows system?
Ok - that helps. Thanks for the hint!
Andreas
On 2019-11-25 10:57, Nathan Woodrow wrote:
> Hey,
> They should be going into whatever %TEMP% is set as: In my case that is C:/Users/Nathan/AppData/Local/Temp/ and running one of the GDAL commands outputs this:
> C:/Users/Nathan/AppData/Local/Temp/processing_95803a9cdde54b1f8e28633e7fc16ccb/2834f0fd8fc4455485a212fb405c38c8/OUTPUT.gpkg
> Regards,
> Nathan
> On Mon, Nov 25, 2019 at 7:53 PM Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi,
>> I would like to know where the temporary files of QGIS processing are stored? I know that there is a setting for default output files (defaults on Windows to C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs - but is this really the same location where also temporary files that are needed during the processing are stored?
>> Our issues is that several users share Windows servers and the C partition is only 80GB in size. If 5-10 users are sharing one Windows server, we fear that our C drive is filled really quickly.
>> Can we set another temporary drive/folder than "C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs" ? If yes, where do I find this setting?
>> Thank you for your help,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191125/c27dba3c/attachment.html>
