[QGIS-Developer] Temporary folders for processing
Nathan Woodrow
madmanwoo at gmail.com
Mon Nov 25 01:57:40 PST 2019
Hey,
They should be going into whatever %TEMP% is set as: In my case that
is C:/Users/Nathan/AppData/Local/Temp/
and running one of the GDAL commands outputs this:
C:/Users/Nathan/AppData/Local/Temp/processing_95803a9cdde54b1f8e28633e7fc16ccb/2834f0fd8fc4455485a212fb405c38c8/OUTPUT.gpkg
Regards,
Nathan
On Mon, Nov 25, 2019 at 7:53 PM Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> I would like to know where the temporary files of QGIS processing are
> stored? I know that there is a setting for default output files (defaults
> on Windows
> to C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs
> - but is this really the same location where also temporary files that are
> needed during the processing are stored?
> Our issues is that several users share Windows servers and the C partition
> is only 80GB in size. If 5-10 users are sharing one Windows server, we fear
> that our C drive is filled really quickly.
> Can we set another temporary drive/folder than
> "C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs"
> ? If yes, where do I find this setting?
> Thank you for your help,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191125/daa85e8d/attachment-0001.html>
