[QGIS-Developer] Temporary folders for processing
Alexander Bruy
alexander.bruy at gmail.com
Mon Nov 25 03:23:47 PST 2019
Temporary files are removed on QGIS exit, so if it crashes these files
will be left
untouched. AFAIK on the next run it won't be removed, as folder name is unique
between runs.
пн, 25 лист. 2019 о 12:09 Andreas Neumann <a.neumann at carto.net> пише:
> Thanks Nathan and Alex.
> My follow-up question is: when are these temporary files cleaned/removed? I assume after the process finished - but what happens if QGIS crashes wile processing is running? Will QGIS clean up the old temporary files when it is started the next time?
> Thanks,
> Andreas
> On 2019-11-25 11:06, Alexander Bruy wrote:
> Hi Andreas,
> Processing keeps al temporary files and outputs in the user temporary folder,
> e.g. C:\Usres\user\AppData\Local\Temp\ on WIndows by default and /tmp on Linux.
> пн, 25 лист. 2019 о 11:53 Andreas Neumann <a.neumann at carto.net> пише:
> Hi,
> I would like to know where the temporary files of QGIS processing are stored? I know that there is a setting for default output files (defaults on Windows to C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs - but is this really the same location where also temporary files that are needed during the processing are stored?
> Our issues is that several users share Windows servers and the C partition is only 80GB in size. If 5-10 users are sharing one Windows server, we fear that our C drive is filled really quickly.
> Can we set another temporary drive/folder than "C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs" ? If yes, where do I find this setting?
> Thank you for your help,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
