[QGIS-Developer] Temporary folders for processing
Nyall Dawson
nyall.dawson at gmail.com
Mon Nov 25 15:07:16 PST 2019
On Mon, 25 Nov 2019 at 21:24, Alexander Bruy <alexander.bruy at gmail.com> wrote:
> Temporary files are removed on QGIS exit, so if it crashes these files
> will be left
> untouched. AFAIK on the next run it won't be removed, as folder name is unique
> between runs.
Just to round out this discussion - if QGIS does crash, then these
files are still likely to be cleaned up by the operating system
itself. E.g. on linux they'll be cleaned out at next reboot.
Nyall
> пн, 25 лист. 2019 о 12:09 Andreas Neumann <a.neumann at carto.net> пише:
> > Thanks Nathan and Alex.
> > My follow-up question is: when are these temporary files cleaned/removed? I assume after the process finished - but what happens if QGIS crashes wile processing is running? Will QGIS clean up the old temporary files when it is started the next time?
> > Thanks,
> > Andreas
> > On 2019-11-25 11:06, Alexander Bruy wrote:
> > Hi Andreas,
> > Processing keeps al temporary files and outputs in the user temporary folder,
> > e.g. C:\Usres\user\AppData\Local\Temp\ on WIndows by default and /tmp on Linux.
> > пн, 25 лист. 2019 о 11:53 Andreas Neumann <a.neumann at carto.net> пише:
> > Hi,
> > I would like to know where the temporary files of QGIS processing are stored? I know that there is a setting for default output files (defaults on Windows to C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs - but is this really the same location where also temporary files that are needed during the processing are stored?
> > Our issues is that several users share Windows servers and the C partition is only 80GB in size. If 5-10 users are sharing one Windows server, we fear that our C drive is filled really quickly.
> > Can we set another temporary drive/folder than "C:\Users\username\AppData\Roaming\QGIS\QGIS3\profiles\profilename\processing\outputs" ? If yes, where do I find this setting?
> > Thank you for your help,
> > Andreas
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
