[QGIS-Developer] Instalacion de Qgis en Rhel 7 u 8
Luigi Pirelli luipir at gmail.com
Wed Nov 27 00:24:18 PST 2019
Hi Fabian
this is a english speaking mailing list!
btw if you need latest stuffs you shouldn't use redhat that is a
conservative (certified oriented) distribution. BUT you can override the
problem running qgis ina docker container. RedHat should have docker...
then just do:
docker pull qgis:qgis:latest (or whatever version).
Tha fact that qgis on docker is based on ubuntu does not means that it does
not work on redhat... ubuntu is only the container context in which qgis is
running.
If you need more spanish speaking support you can check mailing list of
telegram group... look for info here: http://qgis.es/ or the mexican group
and so on...
regards
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Book: Mastering QGIS3 - 3rd Edition
<https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
* Hire a team: http://www.qcooperative.net
On Tue, 26 Nov 2019 at 22:06, Fabian Jimenez <ffabianjimenez at gmail.com>
wrote:
> Actualmente cuento con Qgis 2.14.1 en un servidor Linux RedHat 7.3, sin
> embargo, no he podido hacer el upgrade a 3.x por medio de rpm o hacer la
> instalacion inicial por este mismo medio, ya que marca dependencias
> infinitas que aun teniendolos en un repositorio local, me sigue marcando el
> error.
> Tendra algun repositorio para la version Qgis 3.x o alguna documentacion
> donde me pueda basar para hacer dicha instalacion.?
> Por otro lado, es posible instalar la version 3.10 en un servidor RedHat
> 7.??
> He visto docker con Qgis, sin embargo, estos estan basados en Ubuntu,
> existe un Docker de qgis 3.x para RedHat .?
> De antemano muchas gracias.
> *Ing. Federico Fabián Jiménez Esparza*
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191127/bfc76021/attachment.html>
More information about the QGIS-Developer mailing list
