[QGIS-Developer] LTR management [was Re: Delaying 3.10.1?]
Mathieu Pellerin
nirvn.asia at gmail.com
Wed Nov 27 16:38:37 PST 2019
+1 to end 3.4 cycle a few months early too.
On Thu, Nov 28, 2019, 05:57 Nathan Woodrow <madmanwoo at gmail.com> wrote:
> +1 on dropping support early as the risk is large on breaking the users
> experience with a LTR
> On Thu., 28 Nov. 2019, 8:55 am Even Rouault, <even.rouault at spatialys.com>
> wrote:
>> > I think the issues are deeper then the crashes/projection failures
>> > fixed by the GDAL/proj cherry-picked commits.
>> Yes, actually QGIS 3.4 should not be affected by the PROJ fix, because
>> it
>> uses the old pj_transform() API with doesn't trigger that code path at
>> all.
>> But it *is* affected by exportToProj4() no longer returning +datum or
>> +towgs84
>> in cases where it used to be, which basically makes working with anything
>> WGS 84 fundamentaly broken. The only "fix" would be to backport the fully
>> fledged PROJ 6 support of 3.10 which is obviously unreasonable to do in
>> 3.4
>> > think we SHOULD drop
>> > Windows LTR support early rather than releasing a 3.4 build based on
>> > proj6/gdal3.
>> +1
>> Spatialys - Geospatial professional services
>> http://www.spatialys.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/708b2aee/attachment.html>
