[QGIS-Developer] LTR management [was Re: Delaying 3.10.1?]
Nathan Woodrow madmanwoo at gmail.com
Wed Nov 27 14:57:08 PST 2019
+1 on dropping support early as the risk is large on breaking the users
experience with a LTR
On Thu., 28 Nov. 2019, 8:55 am Even Rouault, <even.rouault at spatialys.com>
wrote:
> > I think the issues are deeper then the crashes/projection failures
> > fixed by the GDAL/proj cherry-picked commits.
> Yes, actually QGIS 3.4 should not be affected by the PROJ fix, because it
> uses the old pj_transform() API with doesn't trigger that code path at
> all.
> But it *is* affected by exportToProj4() no longer returning +datum or
> +towgs84
> in cases where it used to be, which basically makes working with anything
> WGS 84 fundamentaly broken. The only "fix" would be to backport the fully
> fledged PROJ 6 support of 3.10 which is obviously unreasonable to do in 3.4
> > think we SHOULD drop
> > Windows LTR support early rather than releasing a 3.4 build based on
> > proj6/gdal3.
> +1
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/30c3a5d3/attachment.html>
More information about the QGIS-Developer mailing list
