[QGIS-Developer] LTR management [was Re: Delaying 3.10.1?]
Andreas Neumann
a.neumann at carto.net
Thu Nov 28 00:11:07 PST 2019
Hi all,
Thanks all for the discussion.
I would like to hear Jürgen's opinion on it was well. If possible, I
would also prefer Matthias approach. Our organization just recently
introduced 3.4 LTR (I know we are late ;-), we will probably move to
3.10 in mid 2020). It would be nice if the support of the 3.4 release
could be a bit longer, until 3.10 takes over as LTR version.
QGIS.ORG can fund Jürgen for this extra work for supporting two library
versions in parallel, if Jürgen thinks this can be done with a
reasonable amount of work (whatever this means ;-) )
Thanks,
Andreas
On 2019-11-28 09:02, Matthias Kuhn wrote:
> Hi all,
> I enjoy reading the discussion on this tricky topic. Thank you for looking into this!
> What would be the precise plan of action?
> The situation is, a new QGIS 3.4.13 release based on gdal3/proj6 is out already. We cannot make that undone unless we get out the message to forget that 3.4.13 ever existed and ask everyone to reinstall 3.4.12.
> I wonder if it wouldn't be easier to setup a system somewhere to build with the old gdal and proj libraries to create the remaining standalone installers to push out the remaining three 3.4 releases (manually). With LTR we have built a brand with a very good reputation and I think we should protect this label and avoid any controversial communication if reasonably possible.
> It's possible that I am underestimating the work which would be required to do this, but in my opinion this would be a good opportunity to do an ad-hoc investment into Jürgen (given that he has some of his precious time left to actually work on this and that he does not completely disagree with me).
> Best regards
> Matthias
> On 11/28/19 1:47 AM, Nathan Woodrow wrote:
> Just have to make sure we communicate this via the blog and why.
> On Thu, Nov 28, 2019 at 10:38 AM Mathieu Pellerin <nirvn.asia at gmail.com> wrote:
> +1 to end 3.4 cycle a few months early too.
> On Thu, Nov 28, 2019, 05:57 Nathan Woodrow <madmanwoo at gmail.com> wrote:
> +1 on dropping support early as the risk is large on breaking the users experience with a LTR
> On Thu., 28 Nov. 2019, 8:55 am Even Rouault, <even.rouault at spatialys.com> wrote: > I think the issues are deeper then the crashes/projection failures
>> fixed by the GDAL/proj cherry-picked commits.
> Yes, actually QGIS 3.4 should not be affected by the PROJ fix, because it
> uses the old pj_transform() API with doesn't trigger that code path at all.
> But it *is* affected by exportToProj4() no longer returning +datum or +towgs84
> in cases where it used to be, which basically makes working with anything !=
> WGS 84 fundamentaly broken. The only "fix" would be to backport the fully
> fledged PROJ 6 support of 3.10 which is obviously unreasonable to do in 3.4
>> think we SHOULD drop
>> Windows LTR support early rather than releasing a 3.4 build based on
>> proj6/gdal3.
> +1
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer _______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/a62371a0/attachment.html>
