[QGIS-Developer] masks tooltip in Layer Properties
Régis Haubourg
regis.haubourg at gmail.com
Thu Nov 28 05:47:42 PST 2019
Hi Richard
I think this one is for Hugo. This new tab is designed for the selective
masking described here: https://github.com/qgis/QGIS/pull/30747
The tooltip is obviously wrong and the feature misses some explanation in
the layer property tab. Can you raise an issue ?
Regards,
Régis
Le jeu. 28 nov. 2019 à 14:40, Richard Duivenvoorde <rdmailings at duif.net> a
écrit :
> Using the Layer properties dialog (in master), I spotted an item
> 'Masks'. Could not find any description or clue in the stuff shown.
> But I saw that the tooltip of it shows (see screenie):
> "If the remove duplicate nodes options is activated, duplicate vertices
> will automatically be removed from geometries which are edited on this
> layer".
> Found a documentation item:
> https://github.com/qgis/QGIS-Documentation/issues/4368
> first question would be: what is it, but second question: is the tooltip
> the right one? Is it a copy/paste thingie? Or is it just not (yet)
> telling what this tab is for :-)
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191128/7c813f1f/attachment.html>
