[QGIS-Developer] Is qgis_sip_uptodate test giving false negative ?
Sandro Santilli
strk at kbt.io
Tue Oct 1 03:28:39 PDT 2019
Looking at Travis output, the qgis_sip_uptodate test passes:
https://travis-ci.org/qgis/QGIS/jobs/591915632#L958
BUT a test I've added to check if repository files changed
shows that the `python/server/server_auto.sip` file in the
git repository was changed during tests:
https://travis-ci.org/qgis/QGIS/jobs/591915632#L941-L944
Are the two facts contraddictory ?
Reading scripts/sipify.pl it looks like the `-p` switch is
not supported, while the `-s` switch is used for two different
switches (a typo?):
GetOptions ("debug" => \$debug, "sip_output=s" => \$sip_output,
"python_output=s" => \$python_output) && @ARGV == 1;
I mention this because tests/code_layout/test_sipfiles_uptodate.sh
uses the -p switch instead:
./scripts/sipify.pl -p python/${module}/auto_additions/${pyfile}.temp $header |
diff python/$sipfile.in -
So, I suspect sipify.pl is _overriding_ the source file and NEVER producing
a .temp file, resulting in:
1) A false OK message from Travis (no difference!)
2) A modification of source tree during test
--strk;
