[QGIS-Developer] Is qgis_sip_uptodate test giving false negative ?
Sandro Santilli
strk at kbt.io
Tue Oct 1 03:31:13 PDT 2019
Denis, you seem to have introduced both the new switch (with the
typo) and the corresponding call with commit
6301f9b6f3ba1c9b39ffe55698365ab98aa059a1 on May 2018.
I'm not sure how this could have gone unnoticed till now,
maybe the sipify.pl sript should noisily fail when passed
unknown switches ?
--strk;
On Tue, Oct 01, 2019 at 12:28:39PM +0200, Sandro Santilli wrote:
> Looking at Travis output, the qgis_sip_uptodate test passes:
> https://travis-ci.org/qgis/QGIS/jobs/591915632#L958
> BUT a test I've added to check if repository files changed
> shows that the `python/server/server_auto.sip` file in the
> git repository was changed during tests:
> https://travis-ci.org/qgis/QGIS/jobs/591915632#L941-L944
> Are the two facts contraddictory ?
> Reading scripts/sipify.pl it looks like the `-p` switch is
> not supported, while the `-s` switch is used for two different
> switches (a typo?):
> GetOptions ("debug" => \$debug, "sip_output=s" => \$sip_output,
> "python_output=s" => \$python_output) && @ARGV == 1;
> I mention this because tests/code_layout/test_sipfiles_uptodate.sh
> uses the -p switch instead:
> ./scripts/sipify.pl -p python/${module}/auto_additions/${pyfile}.temp $header |
> diff python/$sipfile.in -
> So, I suspect sipify.pl is _overriding_ the source file and NEVER producing
> a .temp file, resulting in:
> 1) A false OK message from Travis (no difference!)
> 2) A modification of source tree during test
> --strk;
