[QGIS-Developer] Is qgis_sip_uptodate test giving false negative ?
Sandro Santilli strk at kbt.io
Tue Oct 1 03:38:07 PDT 2019
Ok sorry for the noise, the OptName=s syntax is to specify that
the option takes an argument, doesn't give an indication of a
corresponding short-version option. I'm still trying to understand
why the server_auto.sip file is modified by travis...
--strk;
On Tue, Oct 01, 2019 at 12:31:13PM +0200, Sandro Santilli wrote:
> Denis, you seem to have introduced both the new switch (with the
> typo) and the corresponding call with commit
> 6301f9b6f3ba1c9b39ffe55698365ab98aa059a1 on May 2018.
> I'm not sure how this could have gone unnoticed till now,
> maybe the sipify.pl sript should noisily fail when passed
> unknown switches ?
> --strk;
> On Tue, Oct 01, 2019 at 12:28:39PM +0200, Sandro Santilli wrote:
> > Looking at Travis output, the qgis_sip_uptodate test passes:
> >   https://travis-ci.org/qgis/QGIS/jobs/591915632#L958
> > BUT a test I've added to check if repository files changed
> > shows that the `python/server/server_auto.sip` file in the
> > git repository was changed during tests:
> >   https://travis-ci.org/qgis/QGIS/jobs/591915632#L941-L944
> > Are the two facts contraddictory ?
> > Reading scripts/sipify.pl it looks like the `-p` switch is
> > not supported, while the `-s` switch is used for two different
> > switches (a typo?):
> >     GetOptions ("debug" => \$debug, "sip_output=s" => \$sip_output,
> > 							  "python_output=s" => \$python_output) && @ARGV == 1;
> > I mention this because tests/code_layout/test_sipfiles_uptodate.sh
> > uses the -p switch instead:
> > 		./scripts/sipify.pl -p python/${module}/auto_additions/${pyfile}.temp $header |
> > 				diff python/$sipfile.in -
> > So, I suspect sipify.pl is _overriding_ the source file and NEVER producing
> > a .temp file, resulting in:
> >   1) A false OK message from Travis (no difference!)
> > 	2) A modification of source tree during test
> > --strk;
More information about the QGIS-Developer mailing list
