[QGIS-Developer] New plugin: Review / Procedure
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 4 23:46:54 PDT 2019
Thanks Harrissou, indeed I meant
http://plugins.qgis.org/plugins/QuickOSM/
Cheers.
On 05/10/19 07:39, Harrissou wrote:
> Hi,
> And there's also QuickOSM plugin that I think provides this kind of feature.
> Cheers,
> Harrissou
> Le 5 octobre 2019 07:22:10 GMT+02:00, Paolo Cavallini
> <cavallini at faunalia.it> a écrit :
> Hi Richard,
> On 05/10/19 04:36, Richard Marsden wrote:
> Should I simply submit as say, v0.1, mark it experimental, and
> perhaps
> add some notes considering its early state. Or should I put it on
> Github (where it will also probably end up anyway) and announce it
> here? Or an alternative?
> I would suggest the first option is the most effective.
> The plugin is called OSMImporter and is intended to import
> layer(s) of
> features types from OpenStreetMap data. The original use case was to
> import a single Administration Boundary level (e.g. US counties)
> into
> a multipolygon layer; but there are also options for railways,
> water;
> buildings. Roads, POIs, and Land-Use are still to be implemented
> - and
> more can be easily added.
> what do you think are the limitation of the current OSM Downloader
> plugin? In general I would advise towards improving the existing rather
> than duplicating the functionality.
> Cheers.
> Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser
> ma brièveté.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
