[QGIS-Developer] New plugin: Review / Procedure
Harrissou
delazj at gmail.com
Fri Oct 4 22:39:31 PDT 2019
And there's also QuickOSM plugin that I think provides this kind of feature.
Cheers,
Harrissou
Le 5 octobre 2019 07:22:10 GMT+02:00, Paolo Cavallini <cavallini at faunalia.it> a écrit :
>Hi Richard,
>On 05/10/19 04:36, Richard Marsden wrote:
>> Should I simply submit as say, v0.1, mark it experimental, and
>perhaps
>> add some notes considering its early state. Or should I put it on
>> Github (where it will also probably end up anyway) and announce it
>> here? Or an alternative?
>I would suggest the first option is the most effective.
>> The plugin is called OSMImporter and is intended to import layer(s)
>of
>> features types from OpenStreetMap data. The original use case was to
>> import a single Administration Boundary level (e.g. US counties) into
>> a multipolygon layer; but there are also options for railways, water;
>> buildings. Roads, POIs, and Land-Use are still to be implemented -
>and
>> more can be easily added.
>what do you think are the limitation of the current OSM Downloader
>plugin? In general I would advise towards improving the existing rather
>than duplicating the functionality.
>Cheers.
>Paolo Cavallini - www.faunalia.eu
>QGIS.ORG Chair:
>http://planet.qgis.org/planet/user/28/tag/qgis%20board/
>_______________________________________________
>QGIS-Developer mailing list
>QGIS-Developer at lists.osgeo.org
>List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191005/b574d602/attachment.html>
