[QGIS-Developer] New plugin: Review / Procedure
Paolo Cavallini cavallini at faunalia.it
Fri Oct 4 22:22:10 PDT 2019
Hi Richard,
On 05/10/19 04:36, Richard Marsden wrote:
> Should I simply submit as say, v0.1, mark it experimental, and perhaps
> add some notes considering its early state.  Or should I put it on
> Github (where it will also probably end up anyway) and announce it
> here?  Or an alternative?
I would suggest the first option is the most effective.
> The plugin is called OSMImporter and is intended to import layer(s) of
> features types from OpenStreetMap data. The original use case was to
> import a single Administration Boundary level (e.g. US counties) into
> a multipolygon layer; but there are also options for railways, water;
> buildings. Roads, POIs, and Land-Use are still to be implemented - and
> more can be easily added.
what do you think are the limitation of the current OSM Downloader
plugin? In general I would advise towards improving the existing rather
than duplicating the functionality.
Cheers.
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
More information about the QGIS-Developer mailing list
